500-Error
Trying to go onto vehicles it says 500 error each time
- Dev
- Creator
- They/Them
- Pro Site Breaker
- Wiki Contributor
I’ll have look into to could you copy and paste the debug trackback please
that happens to me also
Traceback (most recent call last): File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/core/handlers/base.py", line 197, in _get_response response = wrapped_callback(request, callback_args, *callback_kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/fleet/views.py", line 563, in vehicles show_livery = has_non_null_field(serialized_vehicles.data, 'livery') or has_non_null_field(serialized_vehicles.data, 'colour') ^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/rest_framework/serializers.py", line 797, in data ret = super().data ^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/rest_framework/serializers.py", line 251, in data self._data = self.to_representation(self.instance) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/rest_framework/serializers.py", line 716, in to_representation self.child.to_representation(item) for item in iterable ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/rest_framework/serializers.py", line 525, in to_representation for field in fields: File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/rest_framework/serializers.py", line 386, in _readable_fields for field in self.fields.values(): ^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/utils/functional.py", line 47, in get res = instance.dict[self.name] = self.func(instance) ^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/rest_framework/serializers.py", line 374, in fields for key, value in self.get_fields().items(): ... (truncated)
This is the whole thing kai
- Dev
- Creator
- They/Them
- Pro Site Breaker
- Wiki Contributor
perfect ill sort this as soon as i can
I got it trying to delete my HUEM 9.1
500 - Server Error
Something went wrong on our end. Please try again later.
No need to report this - our team has already been notified.
Debug Traceback
Traceback (most recent call last): File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/db/backends/utils.py", line 105, in _execute return self.cursor.execute(sql, params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ psycopg2.errors.UndefinedColumn: column routes_dutytrip.route_link_id does not exist LINE 1: DELETE FROM "routes_dutytrip" WHERE "routes_dutytrip"."route... ^ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/core/handlers/base.py", line 197, in _get_response response = wrapped_callback(request, callback_args, callback_kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/contrib/auth/decorators.py", line 59, in _view_wrapper return view_func(request, args, kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/views/decorators/http.py", line 64, in inner return func(request, *args, kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/fleet/views.py", line 2519, in route_delete route_instance.delete() File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/db/models/base.py", line 1281, in delete return collector.delete() ^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/db/models/deletion.py", line 467, in delete count = qs._raw_delete(using=self.using) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/db/models/query.py", line 1221, in _raw_delete return query.get_compiler(using).execute_sql(ROW_COUNT) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ... (truncated)
Whole thing
ive also got it when logging trips and running boards
Traceback (most recent call last): File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/db/backends/utils.py", line 105, in _execute return self.cursor.execute(sql, params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ psycopg2.errors.UndefinedColumn: column routes_dutytrip.route_link_id does not exist LINE 1: ...utes_dutytrip"."id", "routes_dutytrip"."duty_id", "routes_du... ^ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/core/handlers/base.py", line 197, in _get_response response = wrapped_callback(request, callback_args, *callback_kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/fleet/views.py", line 1098, in duty_detail return render(request, 'duty_detail.html', context) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/shortcuts.py", line 25, in render content = loader.render_to_string(template_name, context, request, using=using) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/template/loader.py", line 62, in render_to_string return template.render(context, request) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/template/backends/django.py", line 107, in render return self.template.render(context) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/site-packages/django/template/base.py", line 171, in render return self._render(context) ^^^^^^^^^^^^^^^^^^^^^ File "/srv/MyBusTimes/.venv/lib/python3.12/ ... (truncated)
- Dev
- Creator
- They/Them
- Pro Site Breaker
- Wiki Contributor
should be fixe
